heads need reconditioning/rebuild
https://forums.aussieveedubbers.com/threads/98736/heads-need-reconditioningrebuild
vertex ·
was wondering if anyone could suggust where I could get some heads rebuilt/recon in queensland
Capn Steve ·
Hi vertex, Also consider new. I Rang Mick Motors today and new heads for my 1600 are $305 ea (complete).
if there only stock ones cheaper in the long run to buy new
vertex wrote:was wondering if anyone could suggust where I could get some heads rebuilt/recon in queensland
I used to Use JAX heads over the years but was told recently they are closed..
vertex ·
vw54 wrote:if there only stock ones cheaper in the long run to buy new
Playing aroung with a 36 hp motor is it easy to buy new cylinder heads for these ones. thanks
psimitar ·
if you have original German heads then I'd get them reconned as the Brazilian ones are hit and miss as to whether they will last well and not crack between the valve seats.
They are far more prone to this than german heads.
I got my heads reconned for $450 at a shop in Geebung, Brisbane. Found them in the yellow pages. He woulda charged me $650 but felt bad charging so much for a pair of old Beetle heads. Anyhow, even $650 reconned with new guides, valves and studs is better than roulette with some brazilian heads at $305 a pop 🙂
36hp heads are not available new.
vertex ·
psimitar wrote:if you have original German heads then I'd get them reconned as the Brazilian ones are hit and miss as to whether they will last well and not crack between the valve seats.
do you know there name. was it Northside cylinder heads
I'd recommend Swift Race Engines. They did do a lot of VW, now under new ownership, but new owner using all the same equipment and ethics. Ph 3277 9792
vertex ·
matberry wrote:I'd recommend Swift Race Engines. They did do a lot of VW, now under new ownership, but new owner using all the same equipment and ethics. Ph 3277 9792
thanks
psimitar ·
Just checked on google maps and it was Northside cylinder heads that did mine. I couldn't fault their workmanship and the exhaust studs were in there like a bitch which took them a lot of effort to remove and replace.
Looks like you have 2 places to choose from that actually do good work these days 🙂
