Clutch cable keeps breaking: 67 Beetle
https://forums.aussieveedubbers.com/threads/98814/clutch-cable-keeps-breaking-67-beetle
butch97 ·
Hi Guys
I'm constantly breaking clutch cables, averaging about 1 or 2 per year in my last couple of bugs.
Does anybody know where I can get one that will last me longer? Something a bit more heavy duty.
I'm getting sick of replacing them, it's not a fun job.
Dave
wHERE ARE THEY BREAKING?
if its near either end it means the cable is bending
You could try a later clutch arm on the gearbox as they were longer [not sure when they changed them?]
Supers?
Do You grease the cable as You put it IN?
heaps of lithium based grease?
You would never want to touch an old cable after that.. lol
Its not the cable or maybe if its cheap chinese
I would be looking at other things like pre tension, the outer tube and angle onto the clutch arm
also get an OEM cable from VVDS in Sydney
Many Years ago I found a company in the USA that made and sold unbreakable clutch and accelerator cables, but they wouldn't post them overseas...
they were not that expensive either..maybe stainless steel??
barls ·
try these guys
http://jaydeeautocables.com.au/
whathaveidone ·
[maybe stainless steel??
Shouldnt use stainless steel!!! It will work harden and break quicker than gal!!
OZ Towdster ·
As said above , whre are they breaking as if it's the same spot each time it could be something as simple as a brocken hard tube that constantly chaffes the cable or a buggered bowden tube that also chaffs the cable
And finally is it a stock clutch pressure plate or a high poundage kennedy etc
I was thinking also of the pedal end too
if the cable end doesn't pivot like it should
the cable would break near that end...
otherwise as said... wherever its bending at
Bowden cable or tube etc
its NOT normal
donn ·
whathaveidone wrote:[maybe stainless steel??
Second that, tried it and failed in 3 months.
vlad01 ·
sounds like someone need to develop pedal clusters with integrated hydraulic clutch. Been done on so many of the popular aussie cars already. Guess the vw is too cheap of a market to invest in 😁
butch97 ·
Hi Guys
Thanks for the replies.
The cables seem to break about 3/4 of the length, down towards the rear of the car.
The clutch tube is firmly attached at either end, im using a stock 1300 with a stock clutch too.
I do put as much grease as I can when replacing them, and you are right Lee I certainly dont wan't to touch them after that.
A friend has suggested that my height may have something to do with it, im 6 foot 5 and tend to depress the clutch pedal pretty close the the floor which could be stretching the cable.
Ill check out Jaydee auto cables, they are just around the corner from my house.
Dave
vlad01 ·
sounds like the clutch tube inside the tunnel is worn through at that point.
butch97 wrote:I'm constantly breaking clutch cables, averaging about 1 or 2 per year in my last couple of bugs.
Are you saying the same thing happens in different cars??
if so - then that is REALLY weird
In 30 years of driving bugs I reckon I could count on one hand the number of cables that have broken and still have fingers left over.
If it is just one car - then I would be laying out the cable beside the tunnel, taking a deep breath, and cutting an access hole to have an explore.
If it is multiple cars - I would be looking at the way you adjust, install and set up your clutches
Keep us updated on what you find out
vwo60 ·
By the catalog they sell automotive electricial cable not clutch cables.
vlad01 ·
ummm I think you guys are look for this mob.
http://www.autocables.com.au/
they make custom cables and what not. I have been recommended them to do my handbrake able to suit my skyline calipers.
vlad01 ·
wait what??
https://vault2.secured-url.com/ShopSecure/autocables/results1.asp?CategoryID=22&CarMake=VOLKSWAGON
I thought that is where many do break [from a very old memory]
so, You may be correct...
You need to re adjust Your cable so the clutch is always depressed when You push the cable in [no grinding]
so I would suggest You unscrew the adjuster slightly until it crunches and then about 1 turn tighter..
You may be adjusting the clutch cable so it actually works a few mms 10-20mm] before it hits the body.. ??
hope that helps
barls ·
vwo60 wrote:http://jaydeeautocables.com.au/
right late night and got the wrong link. my bad
butch97 ·
Hi Guys
Thanks for all the help and sugggestions.
Ill clarify a little bit, in my previous bug i was going through 1 -2 per year, no worries at all.
I bought a new Beetle in Feb this year and broke my first cable on the weekend, continuing my track record of busting one every 6 months or so.
Anyhow, i dropped it off at the mechanics cos I couldn't bear to do it myself, and the good news is that the cable was bone dry, not a bit of grease on it.
I now have a new cable, plenty of grease and the difference in the clutch is amazing.
It feels so light now, and makes me realise there must have been something wrong with my previous Beetle.
Thanks again
Good news...
so, maybe Now You will get a few years worth of wear..
