hey all im after the peice of tinware that goes the furthest back engine for a 74 kombi , i have a 70 1600 beetle engine that i wish to mount..... cheers
in the picture its the shroud that is in front of the alternator and wraps around the engine...
Klaus 路
thats a lowlight wrong type 馃檪 , what your after is the large piece thats getting hard to find but they turn up occ, do u have the crossmember aswell and make sure the 1600 you have has the 3 boss's in the case to bolt it to or you will need the adapter plate that bolts to the oil pump studs
grumble 路
Hi I should have a rear tray for either that or the later bay,pm which one you need.
binner 路
if grumble doesn't find one to suit , I got what you need........
