AN fittings, braided and high performance hoses *SPECIAL OFFER*
https://forums.aussieveedubbers.com/threads/99084/an-fittings-braided-and-high-performance-hoses-special-offer
matberry 路
I've been using Phenix Industries hoses and fittings for many years now and being a Queensland distributer I've been seeing a good quantity of the product. The quality in fit and finish is far superior to any other brand of AN fittings that I have used and I would like others to benifit by converting to Phenix hoses and fittings. I'm sure everyone is feeling the pinch with the GFC and I'd like the VW quality ethic to spread all the way to plumbing your oil and fuel systems. Phenix hoses and fittings are compatible with other AN systems so interchangeability shouldn't be a problem with anyones present systems.
Here is a link to Phenix Industries Australia web home page, I think you'll find the site easy to navigate. http://www.phenixindustries.com.au/index.php
So here is the offer, when placing your online order, mention Matt Berry Motorsports and you will recieve 40% off the already competitive web price (the web price is not including gst and freight).
This is a bargain offer that remains valid untill the end of December 2012 and makes using rubber hoses with barbed fittings obsolete......a no brainer.
Mods please move this if I've posted in the incorect spot. 馃檪
Craig Torrens 路
Good work Matt.....I'm currently building a hot streeter so this will save a few $$ 馃憤
matberry 路
Cheers Craig.....here's some I prepared earlier 馃槈
steve burgess 路
Hi Matt,Thanks for the info will be needing some soon,love the black colour.
Well done last weekend .Steve
bajachris88 路
What kind of thread does the stock vw oil pressure sender use?
Considering an order myself 馃檪
matberry 路
steve burgess wrote:Hi Matt,Thanks for the info will be needing some soon,love the black colour.
Thanks Steve
bajachris88 wrote:What kind of thread does the stock vw oil pressure sender use?
Stock oil pressure sender is M10x1mm
waltermitty 路
great product phenix and good deal. mitchell
matberry 路
Thanbks Waltermitty.
Offer still running, get in quick
hulbyw 路
Good offer however I may need some help before I order. I drive a 1968 1500 Beetle. I have a Gene Berg relief valve oil pump cover, a supposedly original EMPI filter bracket/housing and my case has been tapped for full flow, but no right angle fitting yet. If I mount the filter on the bumper bracket under the guard, can you suggest what fittings I will need and what length braided hoses? The picture above with the Scat rocker cover looks to be the simplest fitment with regards to lack of elbows, but I am open to suggestions, as I have never fitted full flow before.
Another question, with the filter mounted in the guard, does it need a mesh guard around it to stop stones damaging it?
Cheers.........Wayne
whathaveidone 路
after blowing a rubber pushlock fitting off at Warwick and pumping nearly all the oil out of my engine im going to up grade to braided lines so this is just in time. Thanks Matt
Ps. Ive got alot of good used -6 & -8 pushlock fittings for sale if anyone is interested (can not guarantee they wont come off again)馃榾馃槀
matberry 路
hulbyw wrote:Good offer however I may need some help before I order. I drive a 1968 1500 Beetle. I have a Gene Berg relief valve oil pump cover, a supposedly original EMPI filter bracket/housing and my case has been tapped for full flow, but no right angle fitting yet. If I mount the filter on the bumper bracket under the guard, can you suggest what fittings I will need and what length braided hoses? The picture above with the Scat rocker cover looks to be the simplest fitment with regards to lack of elbows, but I am open to suggestions, as I have never fitted full flow before.
I'm happy to help, but to suggest fittings there are a few more things to consider. Things like, is your engine solid mounted or stock engine mounts, and what type of hose do you desire? If it's prone to quite a lot of movement as with std mounts, the style of fitting beside the Scat valve cover is a safer method for long term street use. That fitting is also the cheapest option in the braided system. Another major factor is exhaust clearance. Maybe take a pic of the area. Remember the braid is best not rubbing on things as it does wear through. Also depending on your prefered hose style, the fittings do vary. The black cloth covered hose is more stock looking, lighter than stainless braid, yet it uses the same fittings. On the otherhand, there is the rubber pushon style like the fittings in the last pick above, and the installation pictured below. This system is also a cheaper and a quicker install than the braided systems. As for protection of your oil filter, thats up to you and the style of driving you do.
hulbyw 路
Thanks Matt. Engine mounts will be stock as this is a streeter with a soon to be built 1776. Will probably go with a Vintage Speed Superflow (can you do deals on these as well?) with heater boxes. Not really fussed with looks, just want quality hoses that won't fall off the end fittings
reub 路
Sweet Matt. Cheers.
Might save me buying from overseas...
Reubs
matberry 路
hulbyw wrote:Thanks Matt. Engine mounts will be stock as this is a streeter with a soon to be built 1776. Will probably go with a Vintage Speed Superflow (can you do deals on these as well?) with heater boxes. Not really fussed with looks, just want quality hoses that won't fall off the end fittings
If you decide what style hose and colour of fittings I'll do a recomendation for you by part #. Basically you'll need 4x 3/8NPT to -8 adapters, 2x straight, 1x 90* & 1x 45* hose fittings in -8. 2x meters of hose so you have plenty. Hose is available per meter and the hoses are generally around 650-800mm long (and there's two).
I can also help with the Vintage Speed exhaust, I'd actually recommend the Sport version for your smaller engine mainly because they are nice and quiet.
matberry 路
whathaveidone wrote:after blowing a rubber pushlock fitting off at Warwick and pumping nearly all the oil out of my engine im going to up grade to braided lines so this is just in time. Thanks Matt
reub wrote:Sweet Matt. Cheers.
Reubs
Sweet as guy's. 馃憤馃憤
hulbyw 路
Braided stainless and blue/red fittings. Sent a PM about the exhaust
matberry 路
hulbyw wrote:Braided stainless and blue/red fittings. Sent a PM about the exhaust
List sent via PM.
If any one wants suggestions feel free to ask.
matberry 路
Get your orders in fella's, November already.......
nils 路
Why is this the first i have seen of this thread? Sounds like the ticket for moving the oil filter on the subi motor
matberry 路
December guy's. Keep those orders coming.
Check the web site, many new products added.
whathaveidone 路
ooh shit. I forgot all about this!!!!!!!
matberry 路
Had a few people take advantage of this....remember 40% OFF 馃檪
Time is running out folks, get those orders in.
Stanley 路
Damn....not back until new years eve and I need some fittings.
hulbyw 路
Hope to receive my hose and fittings tomorrow. Phenix really good to deal with. I suggest though that anyone ordering verify their order with Phenix cos my original order from their website was way off
matberry 路
Thanks for your order Wayne, Im sure you will be happy with the quality of the hose and fittings.
Stanley and those others having difficulty getting your orders in on time, I have been able to get an extension to maintain December pricing with the 40% discount for a few weeks into the new year. 馃檪馃榿
BeetleJuice 路
Pity I didn't know about these when I did mine...I know now!
