Now have a 56 oval in garage. Bye buggy. Got some questions...
1. Do they share torsion bars with 60s beetles? If so, what spring plates do I need? Ideally I'd like to put in some type three rear bars but is that possible?
2. How does the rear bumpstop setup work on Ovals. Mine seem to be missing.
3. What sort of oil should I put in my Judson? Where would I get it?
hellbugged ·
Oh good stuff!
Where's the pic!
pete wood ·
Where's the info? 😉
1. different torsion bars Type 3 wont fit from memory
2. will have to look at mine
3. Use Auto Trans fluid its 10 grade which is what Judson recomends or same as Marvelous Marvel oil
been using ATF in mine for over 20 years
ian.mezz ·
bump stops
dont they just bolt onto the spring plate where you bolt the axle on ?????
tar76 ·
Don't type 3 bump stops fit as the are smaller in height?
steve burgess ·
Hi Pete. You can use atf as vw54 said but i prefer marvel mystery oil.It can be purchased from skyshop.com.au .It is not that expensive ,not that much more than ATF.
Iam currently rebuilding a judson in member rides.
Ovals do not have bump stops
pete wood ·
Wow, no bumps stops. Interesting.... Thanks for the tip on the marvel oil too.
Hi Pete
I think the oval torsion bars would be heavier than Type 3 bars, they are heavier than 40 hp bars.
Pete what are you intending to do with the car ??? ( why the Type 3 torsion bars )
vlad01 ·
1303Steve wrote:Hi Pete
