FS Bosch Distributor
https://forums.aussieveedubbers.com/threads/99108/fs-bosch-distributor
CH5353 ·
For Sale
Bosch Distributor VJ 4 BR 8
good clean condition, no play in shaft
with cap and rotor button
$100
John
Vic 3555
0419 168 914
Does it have a working vacuum can?
or is it a mechanical only dissy??
whatnow ·
from the code it is a mech only bus dist. fair price too.
sander288 ·
yep good price if it's working!!
It's identical to a bosch 019 but with the VW identification number instead of bosch's
BOSCH Distributor VJ/VJR 4 BR 8
The VJ/VJR 4 BR 8 is the mechanical advance distributor introduced in August 1954 for the VW transporter equipped with the revised 36 hp engine with 6.6:1 compression beginning with chassis No. 20-095 422 and continuing in use through May 1959 with chassis No. 20-469 447. The unit, a mechanical advance distributor, provides approximately 8.5 degrees advance at 1600 rpm as measured at the distributor, 17 degrees at 3200 rpm at the crankshaft.
[the above from VintageWerks.com]
CH5353 ·
SOLD
