Aussie ·
Seems my fuel tank has a very small leak around the threaded fitting at the base. What is the best way to repair? I am assuming something like brazing would be best. What about the repair epoxy type stuff from super cheap etc?
https://forums.aussieveedubbers.com/threads/99200/fuel-tank-repair
Aussie ·
vwo60 ·
20bkombi ·
gordysbeetle ·
Aussie ·
Where abouts did you take it? Was it on the coast?20bkombi wrote:Could take it to a radiator shop they soldered some fittings on to my bus tank. Was $30 for 3 fittings
Aussie ·
I am guessing this is different to standard electrical solder?gordysbeetle wrote:soldering is the safest way. brazing uses a naked flame, to use this method you must purge the tank.
vwo60 ·
20bkombi ·
psimitar ·
^^^WHS.vwo60 wrote:simply block the filler neck up and fill the tank with water, just leave the part that needs repair out of the water. worked every time.
HappyDaze ·
Doesn't work EVERY time, trust me! Tank MUST be purged, as gordysbeetle says.vwo60 wrote:simply block the filler neck up and fill the tank with water, just leave the part that needs repair out of the water. worked every time.
vwo60 ·
IMO a recipe for a trip to the hospital. This is NOT 100% fail safe. I've heard of them still exploding using this method. Beware!HappyDaze wrote:Doesn't work EVERY time, trust me! Tank MUST be purged, as gordysbeetle says.vwo60 wrote:simply block the filler neck up and fill the tank with water, just leave the part that needs repair out of the water. worked every time.
Aparently there is some residual gasses/compounds that stay. Even if it's only 1 in a hundred......I wouldn't take the chance.vwo60 wrote:Worked every time for me. simply filling the tank with water is actually purging it as it displaces all the flamable gas.
Lucky Phil ·
