Indicator problem
https://forums.aussieveedubbers.com/threads/99210/indicator-problem
maxpwr53 ·
Hi everyone. Is there an adjustment you can do to the indicator switch? Mine won't stay on and it is really annoying. I've tried cleaning it but that didn't help. It's on a 64 bug. Cheers
Lucky Phil ·
No adjustments.
Probably old age.
I suspect you may need a new switch.
maxpwr53 ·
No worries. Thanks.
vwo60 ·
You can disassemble the switch and using a dremal clean up the step on the boss were the tab sits when it is in the on position, i just did this to my karmann ghia switch
and it works as it should.
