AUTOCRAFT ENGINE
https://forums.aussieveedubbers.com/threads/99251/autocraft-engine
RodPenrose ·
I am cleaning up the shed once again and have found 6 complete Autocraft engines here that I am not using and would like to either sell , or sponsor other racers with . These engine are complete and either need a freshen up or can be modified for a particular use .
I have the complete methanol mechanical injection , or intake manifolds for carbs for all of the engines and they are all dry sump cases . I also have the complete turbo system as I ran it some years ago . All engines are race only and are suitable for any vw type of transmission .
These engines range from the small 2276 cc up to the large 2854 cc deal , they are available in 94mm , 96.5mm , 98mm and the 101.6mm bore with crank sizes from 82mm to 88mm . I also have spare cases , heads , injection parts and oil pumps .
I have been using and collecting parts since 1994 and would like to move all of this along as I will never use it again .
All of these engines and components are located in Wollongong NSW and can be viewed anytime . A complete engine , freshened up and ready to start with the clutch , fuel injection , linkage , exhaust , dry sump pump and ignition will be priced from around $ 8000 for the small engines . I can also off a complete turn key deal with dyno report if necessary , ROD , 02-42729920 .
turboty ·
pm me with details on turbo set up please
humpty ·
Oh Rodney.... You should never tease me with your wares.
