Industrial Generator12v with 6v casing 2nd Unit, use it on you 36hp *SOLD*
https://forums.aussieveedubbers.com/threads/99268/industrial-generator12v-with-6v-casing-2nd-unit-use-it-on-you-36hp-sold
mackaymanx ·
SOLD SOLD SOLD
Industrial generator 12 volt in 6 volt casing, use it on your 36hp or Porsche 356.
Condition is used,field coils have been rewound at some stage, commutator is good.
I have replaced the bearings (SKF) so I could run it up. It put out about 10 amps to charge a battery so it does work.
This is a German generator but the armature is a replacement brazilian unit.
Location Mackay 4740
Price $200
SOLD SOLD SOLD
SOLD SOLD SOLD
Open to offers on starter
Starter from industrial motor. This is a 12 volt starter with 6 volt pinion and shaft size.
Condition is used, commutator has been machined some time in the past and is in good condition, brushes are good, some pitting on shaft and rust on solenoid as per photos.
This will need cleaning up, I given it a quick clean and lube, has been tested and does run(static test in vice)
$100
SOLD SOLD SOLD
SOLD SOLD SOLD
Generator from industrial motor. Use it on your 36hp or Porsche 356.
Bosch 0 101 206 116
VW 113 903 031
IND BRASILEIRA
14V 38A
Price $200
SOLD SOLD SOLD
mackaymanx ·
Sold pending payment.
mackaymanx ·
New item added
mackaymanx ·
Offers anyone.
smithy68 ·
Pm 'ed
mackaymanx ·
mackaymanx ·
Bit of a mix up, still for sale. Open to offers.
mackaymanx ·
2nd generator has been added.
mackaymanx ·
2nd generator and starter sold pending payment.
If anyone else is interested I may be able to source some more generators. I will have to check on condition and availability.
