Thanks for that. A few of the boys are saying flip the manifold around so it faces the front... Not sure if that works but heading out tomorrow and will try.
mackaymanx ·
Flipping the manifold can be done, but it does depend on the engine. Some are easier than others. RJES sells spacers to raise the manifold which is required on some.
If and when you turn the manifold around you then need to relocate the altinator plus extend varios wires under the manifold .
You are better off to just fit a U bend between the manifold and the throttle body which you then attach the afm to and a pod style air cleaner at the end of that .
Crankykits.com here in Brissy should have a kit in stock that will include a throttle cable mounting bracket and the pre made u bend etc
zeuspig ·
We were just looking at that alternator issue.
I will check out that site today and see what they have, I want to sort it out ASAP
Thanks for that has helped me out
zeuspig ·
I cant seem to find the website for crankykits does anyone have a number for them?
Tried calling and also sent a message but no reply to the number above.
OZ Towdster ·
Paul is on Morton Isl this weekend , but just send Lovebuggy a pm or email as they both have the same product , pauls just the maker and sells them vis his own site, ie Crankykits and through Meyers manx australia
zeuspig ·
Thanks for all your help on that..ended up getting a kit and have it fitted.
Next thing is how or where is a good spot to mount this coil
