Hi all,
Hoping someone is able to help. I've just purchased a 66 VW beetle and i put the key in the drivers door this morning and the whole cylinder came out with the key. The door is locked. When I put the cylinder back in I can't change it to unlock so I've had to take the whole cylinder out and get in through the passenger side. Any ideas how I can fix this myself?
You'll need to get the door open so you can remove the exterior handle. Once removed, the screw that retains the barrel will be obvious to refit, it hopefully has just come loose and fallen out.
lovinbronx ·
Thanks heaps for your help, will give it a crack this week and let you know if it works
psimitar ·
oh, that's a tiny little grub screw that's normal a right cow to get out so I hope it's not lost 🙂
