Aussieveedubbers 路 Tech Talk
Changing Capacitor in distributor
https://forums.aussieveedubbers.com/threads/99405/changing-capacitor-in-distributor
Paulc1964au 路
How difficult is it to replace the capacitor in a distributor in a 69 beetle? Does it come out through the top or bottom of the distributor?
Super1302 路
undo the screw that holds the clip (which also holds the capacitor-from what i remember)
then unplug and pull out from the side as the wire goes to the points.
i think thats it.
馃檪
Paulc1964au 路
Super1302 wrote:undo the screw that holds the clip (which also holds the capacitor-from what i remember)
i think thats it.
馃檪
thanks will give it a try
psimitar 路
internal condensers are removed thro the top where the dizzy cap sits. Should be able to see where the mounting screw is on the side 馃檪
