Stick clear of the EMPI one. i had the seal come loose in the slip-in style housing. made a hell of a mess. Smoke out the back in in the cabin on the highway to warwick 2011 made me fear an engine bay fire
Original VW style was for the crank pulley to not be sealed such that air would pass into the case, and vent out the vacuum of the stock breather. If the vw engine is exposed often to excessive dust (eg. baja/buggy offroad), you could imagine where its going to go (eek!). However there was a point to this breathing methodology to reprocess and combust any crankcase blowby and keep it out of the oil.
Bit more of a read here:
http://www.vw-resource.com/air_cleaner.html#crankcase
I slabbed a loctite equivalent but cheaper 'bearing retaining compound' to assist in holding the seal mount in place.
Word of warning, alot of sand seal kits are listed as having either 6 inch pulleys or don't say anything in regards to the diameter, excluding the important fact that they are smaller diameter than stock crank pulleys (IE: Power pulleys). Of course, this reduces reduces fan speed due to pulley ratio. Insist on 7inch stock diameter style pulley unless you specifically want the power pulley style for your application (Eg: deliberate higher typical engine rpms than stock or short drive duration). And be aware you will need a specific 'sand seal' pulley without the oil slinger swirl, and will need a longer crank pulley bolt.
