Aussieveedubbers · Bugs
Help ID this Kohler clock
https://forums.aussieveedubbers.com/threads/99479/help-id-this-kohler-clock
spannermonkey ·
I picked up this on the weekend ,
I've tracked it back to late 40's -early 50's , my guess is split window beetle or
HEMBULLER
It works
Any ideas ?
What the CASE diameter
spannermonkey ·
Ooh that would help wouldn't it
80mm
waltermitty ·
Mercedes.
Id run with it
M
From memory split is BIG and Oval is 90mm So M may be right with Merc
spannermonkey ·
vw54 wrote:From memory split is BIG and Oval is 90mm So M may be right with Merc
The body is 80mm
The bezel is 90mm
I've had a look at the Mercs & they seem to have Kienzel's
Thanks anyway guys ,more digging
spannermonkey ·
This is another one I've had for a few years ,and haven't been able to find another one with a white face .
I don't have the glass for this one ,and this one works aswell
farkengruven ·
In your auction you said it was 100mm. So which one is it, 80 or 100mm?
http://www.ebay.com.au/itm/221147238333?nma=true&si=PHIWoBmyZihfysVJx1KZAtO7598%3D&rt=nc&_trksid=p4340.l2557&orig_cvip=true#ht_3541wt_922
spannermonkey ·
farkengruven wrote:In your auction you said it was 100mm. So which one is it, 80 or 100mm?
The body is 100mm ,sorry stuffed up my numbers 🤪
The bezel is 110mm
spannermonkey ·
Found it a new home , going into a 50's BMW 😎
