So i want to replace my oil pump with a pump/filter. When I rebuilt the engine i didnt take note of the cam gear type (ie flat vs dished). I did a cam swap/upgrade with Stan Pobjoy so Im assuming that he's given me the same type cam gear type back (he agreed with this assumption when i called him).
The original pump was 26mm and the flange thickness is about 5-6mm. This was replaced by a 30mm pump with the flange thickness of about 12mm.
From this can it be determined for certain which cam gear I've got? I'd prefer not to pull the pump out to check until I'm about to change the pump for the pump/filter
Thanks in advance
- Jon
lauzboy ·
