WHERE TO BUY SMALL 3 BOLT FLANGE FOR EXTRACTORS
https://forums.aussieveedubbers.com/threads/99954/where-to-buy-small-3-bolt-flange-for-extractors
DylanTheDubber ·
Got my extractors on my bug now and they are GREAT!
Thanks to Jeff Walsh he gave me some old extractors he had, they needed some TLC and the mufflers were screwed so i cut the mufflers off and patched up a small hole, sanded and painted them in exhaust paint and im running single stock carby and no heat risers and a 145 main jet and now the car is goen great!
Only Problem is i need to quieten it down cause i have blueslip on monday.
Les Gave me an old Hot Dog muffler that i want to use but i need another flange to weld it too, it is the small 3 bolt flange.
Where can i buy one?
From Dylan
Klaus ·
exhaust shop
DylanTheDubber ·
do they will have one that fits the empi small 3 bolt pattern?
Klaus ·
if not they should be able to cut one up or change out the one on your existing exhaust
nils ·
Best mufflers on the net, great service and price.
guy who owns/runs the place also does the site and answers the phone. Very helpful if you cant work out exactly what you need and where it is on the site
Calcool ·
Volksbahn in Sydney used to sell the S&S headers small 3 bolt flange, they may still do them.
David
VVDS
Lucky Phil ·
Try stuffing some chicken wire up the tailpipe.
It has worked for me in the past.
pudgy ·
I have a spare if you'd like, going cheap. I'm in BNE but can post. PM if interested.
TorxKiwi ·
If you just want a temporary silencer for the blue slip use steel wool. Jam it in really tight with a broom stick or you'll have a little stainless steel wool cannon ball with an instantaneous increase in volume. You'll get a massive decrease in volume, it worked a treat for my roadworthy. It'll take the pressure off you and you can work on your long term solution in your own time.
