Any GoPro experts?
1303Steve - February 22nd, 2013 at 09:11 AM
I have a Hero2 with a wifi back.
If I plug the charge cable into the wifi back will this charge the camera as well?
I've tried plugging it into the wifi back but the camera charge light doesn't come on.
I don't have a skeleton case only a skeleton back otherwise I would plug directly into the camera.
turboty - February 23rd, 2013 at 09:52 AM
no it wont charge the camera if its plugged into the wifi.. they are not electrically connected separate batteries...
just take it out of the housing to charge the go pro...
Sides - February 23rd, 2013 at 12:26 PM
Yup - as above have to charge em separately.
Watch out with the wifi backpac tho - when you charge it it puts the wifi on in listen mode, and have to turn it off (so screen goes blank) or it'll just drain again.
1303Steve - February 23rd, 2013 at 01:07 PM
Thanks guys, it did say in the instructions for the wifi, if the wifi battery goes flat it will take power from the camera battery, I guess just not the other way.
So if I keep the camera battery charged I should be OK.
PS Edit I have a damaged regular housing, the son drove over with his drift car, the lens is scratched so I could remove the lens and make it a skeleton housing?
turboty - February 23rd, 2013 at 04:16 PM
You could or you could just get a new lense on ebay for about $6... new housing about $20-$30.... I did the same this about 3mth ago...:lol:
Sides - February 26th, 2013 at 07:43 AM
Lens is replaceable, but possible better off with a new housing... lots of people having probs getting them watertight again.
btw - make sure you have the Jan firmware update in the wifi bacpac - the dreaded "freeze" problem hit me over the weekend, and latest firmware seems to have fixed it.
1303Steve - February 26th, 2013 at 01:38 PM
I only wanted to buy a lense to use the old housing I have laying around, the replament lens is nearly as dear as a housing, I thought I could use it like a skeleton case for inside car use only.
Has anybody seen these Vector Mounts, unreal footage http://youtu.be/-xh4zfeHB6Y
