No idea. Still looking. At least the alerting functionality is working!
thanks
Andrew
And I was blaming my own systems. A small relief but good to see AVD is still alive
Thank God!
Disk space - fine.
CPU Load - fine.
Network - a lot of incoming connecting states, but nothing outlandish (there's actually a module that protects against the Slowaris style attacks, so
that wasn't it)
MySQL - fine
Apache - hung
- most likely it was mod_pagespeed which was causing a fair few issues in the error log. If it hangs again, I'll turn it off.
So I've patched, and restarted relevant services. All seems up for now.
thanks
Andrew
good work Andrew!
thanks
Yep, thanks mate
So it hit us again, twice in two days. I'm going to disable mod_pagespeed and see if that helps. This does mean that things will *feel* a bit slower
as it'll be back to normal unaccelerated speeds, and extra latency, but no crashes == good.
thanks
Andrew
Backup done, now I need to get the backup to somewhere else whilst I check this out.
Thanks for your handiwork..its over my head but much appreciated.
Yep, thanks Andew.
Hey Snitz, I hea it's like upgading om a 1600 to a 1915.
