How much would one ecpect to pay for a set of 40mm Kadrons? I have an opportunity to buy a pair for around $400...would need to get some single port
manifolds and probably a new linkage. Is this a reasonable deal?
Thanks.
Ben.
$400 isn't too bad depending on condition. They are about $800 + new from memory
Thanks Shaun - once again providing me with advice! I think Ill have to buy you a beer when I eventually cross paths with you...
Benny just make sure their complete and DON'T have to much shaft play and the throttle spray pipes are tight , and expect to have to put kits
through them .
Plus as most kaddies are a few years old now and have been overtightened around the float bowls by now i would recomend taping some wet and dry paper
to a nice flat piece of thick glass and faceing up the bowl lid and base and also the throttle body ceramic disc as both these areas are prone to
leaks
Thanks Andrew.Ill look into it when I receive them -hopefully its not too late
Hoping my fleabay purchase doesnt turn around to bite me!
I have get the SP manifolds and have spoken to Rod and he is going to have a look around the shed for me..
