I did some maintenance today. Who can guess what I did based on the tools I used?
First correct guess gets bragging rights.
Cv's, points, plugs and tappet clearance
Can't read sizes on the spanners clearly, but they LOOK to be 24, 13 and 11.
If so then what Chris said plus wheel alignment and brake bleed.
Tappets, timing (with a non-std dissy clamp bolt?) and plugs...... & adj fan belt
cleaned your spanners.
Polished your army boots?
cant work out the allen key! ive never been able to undo my cv's with an allen key!
rag is way too clean for any of those jobs listed above so I'm with Donn
Allen key for adjusting the fan belt on a type 4, and a 13. I'm assuming the spanners are 10,13 and 22. So maybe a 1700 type 4 as there is no 14 for the 1800/2000 tappet screw......
Re-calibrated your speedo.
I have read oll your comments so far. I probably should have posted the sizes as well.
24mm, 14mm spanners, Stubby and Feelers for checking the tappets on a 2ltr type 4. 24mm goes on the alternator to line up TDC. 14mm is the tappet
screws and stubby and feeler does the adjustment.
5mm Allen, 13mm spanner, 13/16" spark plug socket and 1/2" drive for cylinders 1 and 3 and extension for cylinders 2 and 4, when replacing plugs on
a type 4.
The allen key is for the sump nut on a type 4, the 13mm spanner is for the oil strainer, and the rag can be used to get the filter off.
All in all, I changed the oil, and filter, cleaned the strainer, checked my clearance on the tappets, and replaced all 4 plugs. There are no winners,
as no one considered an oil change.
Good guesses all round, CV's can be done with that tool set, as can a fan belt adjustment. I think the Allen key might change from a 5mm to a 6mm for
the CV's but I didn't post sizes. And the spanners may have had a rub
Thanks for participating.
