Hey fellow dubbers..Im looking to buy some 17x7 Iozzio Fuchs for our 76 bus and was wondering if there is an Australian dealer or stockist for these
wheels?..
.Cheers Jason.
das resto's I think
No luck with Das Resto Haus..they only sell empi 17" Fuchs.Dont mind the Empi wheel but by the time I black out the inside of their Fuchs its going
to make buying IOZZIO Fuchs more appealing.. which are custom made 2-piece forged wheels.The IOZZIO wheels would be even more appealing if the AUD $
was good
We (DAS Resto Parts) can facilitate the process but do not hold them in stock due the variations in diameter (17 and 18) and widths (6 to 10 inches)
and offsets. We have a good rapport with Paul but you are right, the wheels are not cheap.
here is a set we fitted to the red/white splitty we built:
We're happy to help with the process if need be but you'll have to have your offsets and widths all sorted before ordering.
Al
info@dasrestoparts.com.au
Cheers Alan..thanks for the reply. I am looking to fit 17x7s on our 76 tin top Kombi..both front and rear. I guess the offset for our 76 kombi would
be the same as US spec kombis?..The kombi will be stock with no change in wheel track, I am only adjusting springplates and fitting beam adjusters for
a mild drop in height.
Maybe Paul has the specs on file?.Im looking at the Fuchs that are detailed..Ie polished with black inserts.Are you able to PM rough prices?.Excluding
shipping from DAS Resto to Adelaide..Thanks for any info in advance..regards Jason.
