I purchased an original bilstein jack from ISP in LA a few months back but it didn't come with a rod. Does anyone know where I might find one
(preferably in/near Sydney)???
I only seem to be able to find a couple overseas and you have to purchase the whole jack to get it... Not ideal!
Cheers guys.
Kat
Kat ive got one you can have.
How much do you want for it?
Could i be a real pain in the ass and enquire as to how much it would cost to post to sydney?
My problem is i am overseas at the moment and get home on the 16th, but i'm driving the square down to melb on the 17th/18th,
It would be ideal to have a fully functioning jack-setup for such a long journey methinks!
If that isn't possible, i have a bit of a blonde question:
will any jack be ok to use on the car (such as one from autobarn) or does it have to be a specific size (ie. bilstien one).
cheers buddy, you're a legend
Ok UberKafer, thanks for the advice, so long as a scissor jack will be fine to use/ fit the car fine and so long as if i get a flat i can jack the car
up, then it's all good!
What sort of issues are you talking about with the originals?
the original jack is a bit unstable.
Sometimes when you jack up the car the head of the jack gets close to the car's side panel, if either the foot of the jack slips away from the car or
the car slips sideways away from the jack. So when you try to wind the jack back down you get to a point where the jack is scraping the side panel,
causing damage.
Another issue with the jacks is the ratcheting up and down, its not for the feint hearted, and most non-VW owners wouldnt have a clue how to get it
back down, and have been known to roll the car forward or backward to get it back down, destroying the jacking point.
most people also wouldnt know that to get the front tyres of a beetle off the the ground you have to lift the whole side of the car. But a type3 has
front and rear doesnt it?
Anyway, as I said, its worth doing a dry-run with both jacks with someone who is familiar, so you can see it for yourself. I have seen both floorpan
sides of of a pristine Karmann Ghia butchered by someone who didnt take any care.
Thanks Uber Kafer, really good advice, I shall do just that.I appreciate the help
Type 3 has rear point only. Kat send me your address In a text and will send it down..
Text sent (from a French number so don't delete it, it's not spam haha!).
Cheers Scot, you're a legend
