I have come across a lot of things in my type 3 build that i just want to get out in the open...
this is a list of things you should not do when doing a restoration on a car.
i was hoping others could also list no no's on here too. its not about naming and shaming because some of these i have done when i was younger and
well lets just say more gun ho.
its all about helping people
Do not ever put a fuel filter in the engine bay between the fuel pump and carburettor.
making gaskets from regular paper.. seriously dangerous and just dont!
using expanding foam to fill huge holes with a skim of bog over the top!
using silicone to adhere rubber seals
welding stainless steel to steel, they dont like each other it doesnt work.
using silicone to fill a hole then bogging over the top.
using bog as a seam sealer. bog cracks its not flexible enough for a seam on a car, your seam will rust. seam sealer is cheaper and easier to apply i
promise!
cutting something out of a car for what ever reason and not replacing it. engineers spend a lot of time working out how to protect the occupants of a
car in the event of an accident. if you dont know what something does find out! VW people are friendly and we want to help
oh yeah and using bog instead of a dolly and hammer! even a block of wood can help you pull a dent and save you money on filler.
Take things written on forums too seriously
G'day all. don't tell the missus
ernie
trying to fit beetle parts.
t1 beam conversions
chopping bump stops
t1 upright cooling conversion
lowering too much
using cheap china parts
fitting incorrect wheels, most that fit beetle, don't work so well on type 3
using castrol GTX
just a few off the top of my head.
Don't be in such a rush when putting your engine back in and forget to connect the fuel line from the
fuel pump to the carb and then try to start it...............WOOOOOOFFFFFFFFFFF and the garage glows brightly.
not lowering
Solid mount a daily driven 1915
use a screwdriver to separate case halves.
forget to put the tin under the cylinders before bolting the heads on.
forget to put the piece of tin under the oil cooler before putting the fan housing on a type 4 engine.
forget to put the pushrod retainer springs in when bolting rockers on yout type 4.
drop the spacer washer from the bottom of your dizzy drive into the sump.
overtighten strainer bolts to fix a leak.
use regular plug leads without the tinware seals.
leave heater box pipes open to the engine bay.
silicone your tappet cover gaskets.
fit a battery without sunken terminals under the back seat.
leave out the lockwasher on steering/suspension components.
put your petrol cap on the pump or roof while filling up. I lost 2 or 3 that way!
painting your engine components multiple bright colours
Do not tell other people what they should or shouln't do.
I'm guessing your car came from qld as I've got a DC here with the same issues ..expandafoam is not structural ha
Expandafoam!!! About to undertake removing a heap from heater channel.
Beginning to wonder if everyone has tried this at some stage. Apparently even some manufacturers did this to production cars at some stage.
Fiberglass is not a replacement for sheet metal.
Don't weld with galvanized metal.
Its your car, do what you feel is correct and within legality!!
Amazed of the comments of the "experts" here that haven't restored their own cars
-Replace Modulator valve, and tighten with Vice Grip on its body, because you don't have the correct spanner.
-Use Penrite HPR
IF you haven't got the money up front to restore a vehicle to the dream,
rather than let it sit in the shed for 6 years demotivating yourself as you drip feed in cash, built it to a state of rwc and drive it. It'll keep
you motivated. Then build as you go.
Also, do it right, do it once. There are no shortcuts. You'll find yourself having to repeat the task. This includes rust, paint etc.
Wish i did that ![]()
it helps to joint a car club and get it on club plates. The rules atm dont require a rwc, but they are thinking about changing that one will be required, so get on to it soon and you can drive it around!
Don't hack a dirty great hole in your transmition tunnel to put your clutch cable on
All it takes is a rubber band people
Don't remove tinware and chuck it away it's there for a reason!!
or you could use the access plate on the front of the tunnel to put your hand in and hook the cable on.
did you ever try ?
yeah? was easy, much easier than most other cable operated clutched I changed cables on.
trying to pull though and clip on a cable in a more modern car with it in the dash setup. fark!!!
Always have oil pressure when starting a new engine
^ very well written break down of the procedure.
good point on the plugs being removed. I did this on a recent engine with minor overhaul and mods.
oil pressured remained high for the light to be out for over 3 min after I stopped cranking. was very impressed with my mods/overhaul of the oiling
system to hold pressure for that long !
when bolt on clutch to transmission breaks don't rely on one bolt to hold it in place...just saying.....
