Morning all, just wondering if anyone knows where I can buy some of the blue line brake hose that joins the bits of hard drawn line from the brake
reservoir to the master cylinder. Also the 2 plastic elbows and the grommets that plug into the master cylinder. Sorry if this is a silly question but
we have only just bought the beetle and just need a bit of guidance
Many thanks, Peter.
If you get the correct size original spec braided line, that should work Peter.
Others will confirm...
VVDS Sydney 02-9789-1777 Genuine blue tubing don't buy anything else it DONT work
If you use braided fuel hose, it will dissolve.
Get the correct hose.
If Boris can't help which will be surprising try Tooley Imports at Hornsby 94762888
