Hi there,
The automatic renewal of the TLS certificate did not fire. I think I know the reason (some of the other domains I'd let expire), but to avoid the
issue in the future, I've removed those domains from this certificate, so hopefully automated renewal will just occur transparently in the future.
thanks
Andrew
Thanks for your work. Much appreciated
Yes thanks for your work as well I was wondering what was going on
Thank you ![]()
I could see there was a problem and I figured you would sort it out.
Thank you very much
