Hi there,
I am looking for some details of Body (Chassis) and engine numbers! Specefic to a 1952 T1 to 1955 T1.
Here is a hint (I may have found an EARLY) beetle; I need to clarify the Chassis/engine numbers to give confirmation.
I am eager to go and have a look at the vehicle (AM 10 Dec 03) with the above data to confirm my beliefs.
Any help from the historians out there would be appreciated.
Regards
Mck H
Try this
http://www.bug-bits.freeserve.co.uk/bugbits/data.htm
Silver
The Chassis number should read 1- something if its earlier than 55.
should be a number under 1 million if theres no dash after the 1 then its later than 1 million.
Thanks guys,
Thank you both for the help.
Will give a detailed brief of todays happenings in another part of the forum.
Regards
Mick H
