i was wondering where can u get those plastic air scoops for kombi's and how much they cost prefrably in newcastle area
Give Alec a ring from Klub VW DD
0412126784 / 0746322571
klubvwdd@bigpond.com
He also sells under under dash trays, emblems amongst others. He also has a good range of second hand stuff.
:thumb
why do you need the scoops. i have the stock scoops - as part of the car body and i dont have a problem with heating. are you overheating?
nah ive just heard it improves engine performance and just keeps it that little bit cooler
Available from Vintage in Sydney 9789-1777 they have them in stock
would the benefits of "scooping" more air into the engine bay be outweighed by the extra drag of hanging a big piece of plastic off each
side of your bus?
just my $0.02
also the build up of extra air in the engine bay is still being expelled through the cooler at the same rate and temp. i am skeptical of their usefulness.
I haven't fitted mine yet, but will keep a cloes eye on oil and head temps when I do, so I will know then if it improves or hinders cooling.
(generally people say they help)
My reason for fitting is not for any gain in cooling, but to keep the weather out when parked :thumb
Yeah, I was sorta wondering why you would worry about drag on a kombi........
My mechanic recommended them if I was going to do long distances over 80 kms/hr.:bounce
I don't reckon ours are ugly
And if you get hungry, I caught a bird in ours once!
dose your kombi have a blow hole? free willy
if youre getting all that extra air in,would you also then be able to prop the lid a bit for even more heat exchange?
no, that lets the fan suck in heat from the exhaust & dust, the extra air from the scoops helps keep hot air out by force feeding cooler air, they seem to work best for me at 85 to 90 kmh - on an unfortunately long neccesary trip on Christmas day at 42 deg ambient, I founfd the temp going up if I went over or under those speeds on the freeway
for my 2c they are like deck lid stand offs on a Type 1
Personal opinion on looks but they will drop temps.
I would definitely run them if i was doing long trips.
My problem is no one makes then for a T2.5 or what ever mine is called
Barry
Its a T3 remember, hows the sale going
Kom - i just noticed all the other beetles.
Was this some sort of VW holiday???
Mine look fine- white ears on a white Kombi
AND THEY WORK!! atleast 7-9 degrees lower in oil temp guage reading after they were fitted
funkin pukka
well i may have been converted. i will consider buying them. how much are they and from where? do you rivet them in or what?
don't rivet them on if you plan to take your kombi to the snow. They will cause your carby's to freeze if it gets cold enough.:bounce
Yes, you rivet them on, and no, they have never caused my carbies to freeze up at the snow.
I bought mine from Alec, I think they were like $35/pair plus freight, but that was quite a while ago....
