Beautiful, much cheaper than resto. Increases rear vision also. I'm thinking tensioned sail wire now.
What was the link you got this from?
actually, tension sail wire would be awesome. have neat little posts and wire like on your deck. :thumb would love to see that.
pity mine has gates. found the pic on the samba.
'cept the wire would sing in the wind, could tune it to play "stairway to heaven".
check out the green bus next to it looks like an intresting door conversion. :o:o:o
wow. didnt see that. looks like a bay ( hmmm could it be an early bay
) door that has been attached by the top. interesting. good for shelter. bad for coles carpark shopping trip.
the green bus is a split if u look carefully u can see the front screen divider
yes. very good... but the cargo door is from a bay! check the window. it is one large and a little quarter in the front
Hows the checker plate sills??????
Dave
Speaking of missing gates, I have sourced another split crew-cab (approx 62-63) which has no gates, I can get single cab gates which can be modified
(bit of a hassle!!!???), or alternatively make some as shown, although timber ones are always good...once I decide which one I'll keep the other
will be up for sale...
Twoguns, have you progressed on yours?
man,not yet. but will be chatting shortly.
