Wiring Diagrams ( & Other Stuff)
Hbbear - February 25th, 2004 at 02:57 PM
If you want them printed BIG email me:
Follow this:
http://www.aussieveedubbers.com/forum/viewthread.php?tid=19138
:thumb
Also, after looking at VintageBus.com if any of you bus boys want the tech specs printed bigger, drop me email also. I'll try and clean them up before printing.
[Edited on 26-2-2004 by Hbbear]
Hbbear - February 26th, 2004 at 09:57 AM
First one away - Oval TOFU u have U2U.:thumb
68AutoBug - February 26th, 2004 at 11:35 AM
I had a sister in Law print a circuit diagram out for Me, from where She worked,... then She changed jobs!!!
Make sure You have the correct circuit diagram for Your Car... just because it says 1968-70 etc... doesn't mean its identical to Your Car... VW made different wiring looms etc for different countries..
Don't use USA diagrams. They are VERY different to those used in Australia. Check the number of fuses in Your fuse box, then check J1 & J2 on the diagram & see if Yours are identical..
Aussie made Beetles 63-67 should be identical. German made 65-66-67 had many differences to Aussie beetles.
Best of Luck..
[Edited on 26-2-2004 by 68AutoBug]
Hbbear - February 26th, 2004 at 01:20 PM
Listen to 68Autobug. I'll only give what was asked for, but if its the wrong one we'll have a look see and I'll reprint the right one once worked out - No Problems!:thumb
Dont forget you only pay postage!!:D
Hbbear - February 26th, 2004 at 04:02 PM
Before and after, imagine them A2 size, print out not too bad.:)
68AutoBug - February 26th, 2004 at 07:53 PM
They are Very good Wiring Diagrams on Vintage..
Up until late 70s when wiring diagrams took on a Block Diagram type...
I hate them....
Maybe they were designed by computers for computers.... not people...
