ok so the drivers door locks with a key but how do you lock the passenger door ..no button, knob ,key hole . i must be missing some thing ,,65 beetle
.help me before i weld a pad lock on
:alien
When your inside the car lean over and push the lever that opens the door forward. This locks the door
Danny:thumb
hey thanks i`ll try that ...knew there had to be a trick to it ..bloody sneaky germans
When i got my first early bug i was the same , LOL
Danny
:thumb
thanks for the info also.... was wondering the same with my 65. will give it a try.
is this meant to happen with the drivers door also or is it only the passenger door???
only the passenger door... you have to look the drivers door with the key..
so you can't lock the drivers door from inside the car while you are in it???
no but why would you want to lock yourself in???
Unless you do it from through the window!!!
mostly just from habit I guess, (am so used to central locking in new cars) and also today's environment.... nice to know that you can at least
lock the doors from the inside of the car if required.
May have to fit central locking on this one.
I've considered locking mine through the window with the key... never actually done it I don't think.
does anyone know the first model & year that the door locks were installed on the inside??
