RESTORING WHITEWALLS
Robo - April 18th, 2004 at 06:28 PM
HI PPL
Is there a paint or some thing similar that can make whitewall inserts white again. I have some inserts but they are a little discoloured.
Thanks Rob...:cool:
65busser - April 18th, 2004 at 07:03 PM
Rob, All you need is Jiff, or a similar white pasty cleaner. Just enough grit to clean 'em without taking too much of the shiney surface off. Go easy with it. Don't scrub the life out of it. I reckon before you do that though, just give 'em a bit of a go with your normal car shampoo and a clean towelling cloth.
You lucky B@$+@#&.....
XXX-1.8T - April 18th, 2004 at 07:39 PM
I use Jif too
Works a treat:party
PHAT BUG - April 18th, 2004 at 07:42 PM
I used to use Jiff too, worked great!
5PL1TDCS10N - April 18th, 2004 at 10:41 PM
Do not use an abrasive type cleaner as it will give the surface more tooth, making them harder to clean later!
Just get Wax & grease remover/prepsol-wipe on wipe off- then apply a silicon based tyre shine(Turtle tyre shine)
It will look brand new and stay clean for ages and make it easier to maintain.
Tested and approved on my Oval....W
Robo - April 19th, 2004 at 10:15 AM
Thanks guys
Will have go into the shed and do it now!
Rob...:cool:
