Does a/body know where I could get one of those Rubber protectors that sit in the cupped area for trolley Jacks to protect the pan when raising the
car?
I've seen them before, don't know the exact name!
Been to Auto Pro & Super Cheap, nothin!
Thanks C.
[ Edited on 29-12-05 by Craig Paton ]
I believe they're called "Jack Pads"!
A piece of plywood works a treat!
Yeh been using that with rags for years.
Want something better for "MY PRecious"!!
What size would you be after?
I have some red neoprene block which may do the job
Hey Grahame
It needsd to be roughly 128mm in diameter and the debth varies because of the internal cone shape.
Thanks Craig
Try this address:
http://www.protechproducts.net/
hth
Thanks! That's exactly what I'm looking for.
Does a/one know if I can get these in Aus.
Craig!!!!!!!!!!!! Does this mean your car is going to see the light of day soon! ( new motor did santa drop it off ) Pics would be nice ( i don't believe it ) My jack pad I made from solid rubber (12mm) then I die grinded small holes for the jack crown ( 5mm deep ).Rubber from Clark's Rubber. Very cheap.
next time you're driving down the highway and on the side of the road, you see the tread that has been thrown from a punctured truck tyre, stop and
pick it up, take it home and cut off a bit to suit your jack...
done and ..........done...
I wouldn't mind one! I was given a chrome racing jack for xmas, it'd go perfect with a jackpad!
Craig,
I sent you a U2U, but did not get a reply????
(I have some red neoprene block which may do the job)
Give me a ring 3355 7943
Hi Graham
I didn't get your u2u! I'll call you on the weekend
Craig
