convertiable W decklid
57 Cal look - February 26th, 2006 at 09:36 PM
Hello all, cant remember who, but somebody was telling me that there is a guy here in Australia, Sydney i think. That can cut / press the air vents like on a convertiable "w" decklid ... into a standard "w" decklid.
Dose anybody here , know who this person is.. or dose anybody here know somebody who could do this sort of job.
cheers,
[ Edited on 26-2-2006 by 57 Cal look ]
LUFTMEISTER - February 26th, 2006 at 10:22 PM
have a go yourself its not that hard if you take it slow. measure twice cut once! do not forget the dremel!
LUFTMEISTER - February 26th, 2006 at 10:28 PM
do not stress about the lid being modified. it was in such a bad state to start with, it was a freebie. you will notice the extra air flow to the engine bay with vents let in. if you put your hand over it and have the engine revved you can feel the air being sucked in. if you want the correct oval vents to use the front vent panel of an early bay(vertical slots just use the correct number of slots) preffered the early sixty slots on mine.
modulus - February 26th, 2006 at 10:34 PM
Kilmartin sheetmetal in Ballarat, Vic.,
did these louvers for an Austin Healey.
hth
LUFTMEISTER - February 26th, 2006 at 10:54 PM
after painting
lohoon - February 27th, 2006 at 04:33 AM
factory cabrio vents ran the same way as ones underneith the window.
