38mm 3/4" drive socket?
66deluxe - June 16th, 2006 at 05:23 PM
Has anyone in Brizvegas got a 38mm 3/4" drive socket that i could borrow for a couple of days. Why, i was about to remove the gland nut from the flywheel and it is a larger size gland nut it's 38mm not 36mm standard. I have a 36 and 46mm socket but no 38mm. Any help will be repaid in a 6 pack of your fav swill. Cheers Damo.
1500S - June 16th, 2006 at 05:26 PM
38.1 mm is the same as a 1 1/2" AF socket. If you have anyone with an imperial set they will get you out of trouble.
DH
66deluxe - June 16th, 2006 at 05:28 PM
Never thought of that, will have to wait till monday now when i get back to work and check if they have one, but still prefer metric if possible.
LUFTMEISTER - June 16th, 2006 at 07:40 PM
get off ya butt and come and get it! (left me mobile at work DOAH!)
66deluxe - June 16th, 2006 at 11:49 PM
Got one, happy days.
1500S - June 17th, 2006 at 08:38 AM
>Never thought of that, will have to wait till monday now when i get back to work and check if they have one, but still prefer metric if possible.<
With 0.1mm being the thickness of a sheet of paper, it doesn't make any difference in the fit on the nut. There are a few sizes in the imperial range which fit metric.
DH
