HAS ANYONE FITTED AN AFTER MARKET CRUISE CONTROL TO A MANUAL NEW BEETLE?? NEED INFO ON WHO DOES THEM. GOT IN CONTACT WITH MY LOCAL BLOKE AND HE DOESNT KNOW MUCH ABOT THEM.
any mechanic should be able to fit a cruise control kit... most are able to be fitted by you if the instructions are detailed enough.
I think from memory the hardest thing to do was fix the magnets to the drive shaft and fit the pulse sensor.
good luck
I have fitted two of these kits to cars I have had but never to a VW.
The kits are fairly simple but require a bit of thought on fitting.
Any mechanic or hady person could fit one. Took me a good 1/2 day to fit it all nicely.
The kits I have used were very generic and could fit any car.
The system disengages when the brake pedal was pushed, if it was being fitted to a manual I would suggest an extra swith to disengage it when the
clutch is pushed as well, to avoid over reving the engine.
Jeremy
