Found some seemingly random stuff in the box of parts in my 54. Anyone see anything familiar?
Can't figure out what these are either. One has one scoring mark and the other has two.
Sorry about the crap photos
top pic from left to right:
generator pulley outer, radio blank off for early 60s T1, part off bonnet stay assemly (2 piece), ???, indicator wire cover on steering shaft for
oval..
dont know the others tho
all these ids are from my memory from pulling the odd vw apart over the years..
hope that that helped to solve your mystery
the 2nd photo is of too pipes used for teh accelerator cable...
was given on.. think they are guide tubes for the cable through the housing... i duno. but i know its got to do with the accelerator cable. if anyone
knows where/how it mounts... please do tell me!
yep look like throttle cable guides, from out of the fan housing to me.
Thanks heaps guys!
the throttle tubes go between the carbie and the dog house, there should be a spring as well.only one per motor!! cheers
I thought they may be ski poles, did you get the dub from Switzerland?
Easy
how to u mount up properly these throttle cable guides?
soz for stealing the thread.. jsut thought while it was mentioned, might as well ask
they slip through the throttle cable holes in the fanshroud (36hp) from the pulley side of the shroud and sit with the wider part of the square stop
at the bottom. (i think they might also go through the tin above the flywheel, but it has been a long time since i played with a 36hp)
it's easy when you write it down, but a bit of a pain when you are trying to do it by yourself with the motor in the car as you have to slide the acc
cable through the tube, while sliding the tube through the fan shroud, with one hand is jammed down between the shroud and the fire wall etc. there is
sure to be a better way than i did it, but....
[ Edited on 30-10-2006 by whatnow ]
