Advice needed on buying a Mk1 Golf - Diesel
pi22api22a - June 11th, 2007 at 10:33 PM
Gday dubbers,,
Been a while since I've posted (I've been without a VW, felt ashamed), anyway that may change as I may have found my next project, but I'm in need of some input / advice from the AVD fraternity,,,,,,
Its only a cheap, Mk1 (pre 1980), GLD (diesel), needs work on brakes, engine has had some work done, dont know much else yet (yet to check it out).
Any advice on what to look for, known rust areas? Tips? Telltale signs?
Looking to restore it to near spec and use as a daily driver,,
Daaaaave:beer
david777 - June 11th, 2007 at 11:32 PM
I had a 1977 petrol golf for a few years.
They often rust in the rear hatch beneath the rear window.
Check carefully the rubber boots on the drive shafts. If they are broken, dirt gets in and you are likely to need expensive CV repairs (a few hundred $ each side)
Turn the steering full lock and drive around slowly each direction and listen for clicking sounds. If so -you have CV problems
Most have cracked dashboards, as they never coped with the heat in Australia.
pi22api22a - June 12th, 2007 at 04:23 PM
thanks Dave, will let you know how it goes,,
megalania - June 13th, 2007 at 05:52 PM
Good luck with the golf, I had a 79 for a little while and absolutely loved it. Went like the clappers.
vwrallycar - June 13th, 2007 at 07:44 PM
keep an eye out for leaking fuel pumps, as the change to low sulphur diesel in the last few years make the seals leak.
mine was a fantastic car, 640kms around town on 36 litres.
pi22api22a - June 19th, 2007 at 04:10 PM
Had a look at it, was up in a farm under a tree
Engine was fine, no probs, fuel pump ok etc, started well from cold, no blowby issues,, butt
too much rust, I'm guessing sitting under a tree for a few years took its toll,, could be worth getting if I can find a shell,,
Anyone got a Mk1 shell lying about in Perth?
Thanks for the tips all,,
daaaaaaaaave
