Dash Board..
VW_Gurl - September 1st, 2007 at 09:22 PM
[img]http://i115.photobucket.com/albums/n284/avwnut/IMG_3953.jpg[/img]
Is this Dash Board meant to be like this for a 1971 model??
[ Edited on 1-9-2007 by VW_Gurl ]
Mike_Hunt - September 1st, 2007 at 09:57 PM
u mean with the plastic coatin?
VW_Gurl - September 1st, 2007 at 10:29 PM
yes.. can it be removed if so how do we take the panic handle off?? n how do u take off the knobs??
1303Steve - September 1st, 2007 at 11:47 PM
The panic handle come off like a steel dash one does, nuts behind the dash, above the glove box. The knob for the light switch undoes and the vent ones just pull off. These padded dashes appeared after 1972 and were fitted to the last bug the 76 model. If you fit it to a pre 71 car you will need to make a hole for your wiper switch.
VW_Gurl - September 2nd, 2007 at 09:02 PM
ok thank you so much..
VW_Gurl - September 3rd, 2007 at 08:20 PM
thank you for ur help our friend came over n help us get it off..
70Beetle - September 7th, 2007 at 07:15 PM
You must have good friends:smirk:
