Hello, just went to check out a bug. It had an empi quick shift which i thought was great. What are these worth? I had a browse over the net and found classicveedub.com sells a "quick shift kit" but its just a small bracket looking thing and costs under $10. Cheers
are you talking an Empi quick shift shifter - as in actual gear stick
or are you talking the quick shict kit that reduces the throw of a stock shifter??
One is worth under $200 (to some anyway) and the other is worth $10.
Both efectivley do the same job
ya the actual stick. $200 pretty cheap i recon for the amount of difference. thanks for the info
what your talking about is call the trigger shifter. they arent bad but they arent as short a shift a a quick shift but they do have a lock out
If the pic attaches like it should but never does thats what it was. The gears were bloody close. didnt seem possible to get any closer. I liked it tho. Cheers for the help
try an 35mm between gears stop to stop thats what ive got at the moment with the dragfast shifter it was 50mm with the quick shift and 60 with the one pictured above
just beware if your gears are worn they will increase the problem but i agree after driving with one i wouldn't drive without one
cheers muzza
