Can someone work this one out,Its a 60,s engine lid with a later push button handle.It looks like its original because its been pressed in and i cant seem to find any where its been cut and welded,is this original or has someone done a good modification????thanks shane.:duh
its of a 68 -70 bug
I thought the 68 - 70 bug had the shorter engine lid????cheers shane.
yeah they do
thats original it was only the very last 67 change over bugs that were like that
ive only ever seen 3 like it urs included
-Joel
my blue was just looking at the shape not the length
Anyone whant to swap for a standard 60,s engine lid in the same good condition as this one
cheers shane.
where are you located? If your in Syd or the ACT I can help.
I have a 67 or earlier lid that you can have for nothing.. It has a had a french cut in for the number plate. Currently located in Waterloo (Inner
Syd).. If you don't need it, its still free to a good home...
Its the bottom one
[ Edited on 30-9-07 by StenGuns ]
Thanks Stenguns but im after a original one,Craig im down nowra but could get the lid up to liverpool,what condition is the one you got in thanks shane.
Forgot to ask craig is it a popes nose???thanks shane.
No its not a Pope nose, it has the same number plate light as yours. Condition is good.
I will get back to you craig,I might have found one with a popes nose thanks shane.
no worries..........................I may have found another buyer.
