Does anyone know whats needed to get a LHD car registered in Vic? I was told I need to get the installation of the seatbelts engineered. What does it
cost and who does it?
As far as I know, there are no special requirements for a LHD car but the car must meet Australian Road Rules (I think that is the legislation?!)
requirements eg: seatbelts must meet Australian standards
Do you mean you need to get non-standard seatbelts engineered? Or the OE seatbelts checked?
Call Vicroads, they will explain all
as long as it is old enough (over 25 years i think?) there are no problems
The car is a 1969 and does not have seatbelts now but I was told I need to get some fitted and engineered
seatbelts where made mandatory after 1966.
find a seatbelt fitting station as they should be able to fit the belts and pass them for the engineers cert all in one hit:thumb
Holdens had factory fitted seatbelts in the front of all cars from 1966, and rears from 1972.
Name a post '66 car that does NOT have seatbelts fitted? VW had them from '62 (front & back) optional. check under your rear seat you will find the seat belt mounting brackets. Law was not retrospective so if your car NEVER had them fitted you do not have to fit them, BUT if they are there, then they have pass inspection.
