In one of the forums,it was said they used a 12v hair dryer as a demister/heater, how long can you run them before over heating the unit or would a caravan 12v heater be better. Also what is the power usage be approx[12vx10amps=120w] or more :thumb
I've found a web site that has 12 volt heaters for sale.
See: http://www1.jaycar.com.au/images_uploaded/Page3...:thumb
My friend that put the 12V hair dryer in the Baja only put them in for legality of "having demister " for rego.
He would never run them for long.
Not sure the power rating. maybe Jacar site has some note..
Jaycar site has a 12 volt heater with two settings 150w and 250w. You probably couldn't run it through the cig. lighter socket. It would have to
be hard wired in with a seperate fuse.
Regards,
Mark:thumb
I had trouble finding it as the short cut didn't work. But once at the Jaycar site, if you do a search for heater it comes up.
Maybe I should get one or two to keep my bum warm this winter.
[Edited on 23-5-2003 by manxed69]
i went to by one from a caravan place tried 6 (two different manufacturers) 3 didn't work at all 2 ran for a combined total of 45 secs the 6th worked but couldn't warm anything more than 2 inches from it
Mmmm, 12 volt hairdryer for the VW just what I need when I've been caught in the rain or been for a swim and my hair's a mess.
Dr L doesn't have a demister double value
Are they as weak as the travel ones?? Gutless wonders that they are.
Couldn't help it, saw the post about a hair dryer:jesus
Here you go Jen
http://195.82.115.180/FMPro?-db=wproducts.fp5&-format=detail.htm&-lay=cgi&-sortfield=name&-sortorder=descend&ID=jka0138&-max=1
0&-recid=36882&-token.0=12697789&-find=
[Edited on 23-5-2003 by fatboy]
Hmm link wont work.
Go to http://www.justkampers.co.uk and search part JKA0138 in the online
catalogue
Looks like my travel one
Can imagine pulling up to a set of lights and blow drying my hair
I'll try the link
JKA0138&-max=10&-recid=36882&-token.0=12697947&-find=
Mmmm, just what I need these cold mornings as well, the windows stay fogged forever almost. Vent window open helps
Steve, strange how your link doesn't work and mine does, exact same:jesus
[Edited on 24-5-2003 by jenz58]
re link, hold your mouse over link, the 'underline' only goes so far, space in the wrong place :p
Actually when the link was posted (and if I go in to edit it) there is no space. some buggy thing in the xml code was inserting it.
the Gestapo were driving a 181 'thing' in the 2nd World War movie on Austar on thursday.. it was complete with 1968> headlamps and wide
front blinkers...
It was painted army green.... I'm not sure whether it was a 1943 colour or not....
:thumb:thumb:thumb
