Well its time to turn my "seudo" vw storage cupboard into the "Kombi Bar"...................This is nicely located in the garage away from any
female influence
So here it is before it transforms into the place of worship.
Hurry up this beers getting heavy mate , oh and i believe its your shout too
nice piece of timber for the bar top..............got to love living next to the bush
, always cheap timber !!!!!
Hey Craig
I can donate the beetle
We can get a collection
A Type 3 .... a KG.........
We could eben chop the front off the rag
I removed the front of the dash (about 2mins work !) to allow the timber to sit level.........................I want to keep the face of the dash in place so i can fit a cd player etc
so should I leave the front of the bar with the rough edge (external trunk) or dress it smooth ???
Follow the curve of the front...
yep, will do. I'm thinking at the front I will leave the trunk surface, just for the look, then bring the timber (dressed) back around to follow the curve.
Although the trunk surface is cool, I think it would look much better as per hotrodmatt's suggestion with the front edge curved to match the front of
the kombi. You could flip it so the rough edge is maintained but faces into the cabin, and the front edge curved and dressed.
Just my 2c though
christ, you old school racers are going balmy.................Jeff and you would get on like a house on fire messing around with your wood
..............now wheres my bloody kafer bar (the aluminium traction
type!)
Yeah curve it and smooth it. I don't want our delicate little fingers getting splinters. Also need space for the flipdown screen for the playstation.
I have a steering wheel and peddles you can have too.
Oh...and the beers are cold.
If you want it left rough (undressed sounds better), with all that bush around, find some timber with the right natural curve!! Imo, shape it to the bus... better aero.
yeah leave the undressed center and shape to the bus with the undressed in the middle section of the bay.. ( like this bracket sybol thingy..
my 2 cents..
gunna be a great asset to ya shed for sure..
hey Graig thats a great Idea,
i hate splinters so I go for smooth and shaped,
Hopefully one day we will get down there to try it out.
Marc & Kathy
you're always welcome for a beer.
At least you won't have go to town on the audio system - just open the roof of the ragtop and crank it! There is a lot of good gear in there
Oh and the deep cycle battery is designed so it can be run flat and recharged
something like 500 times before any damage occurs - designed for audio systems!
Make sure you update the progress pics once you decide what to do with your "wood"
Here is an econoline based bar for some inspiration
updated shots.....................just rough cuts at this stage. Will shape later.
love cutting timber !
nearly in place.............just have to use the router to make it sit back flush with the pillar.
i built a bar using the rear end of a well trashed splitty.
http://i237.photobucket.com/albums/ff192/kombijon/barwork002.jpg
http://i237.photobucket.com/albums/ff192/kombijon/barwork011.jpg
http://i237.photobucket.com/albums/ff192/kombijon/barwork013.jpg
but them either side of a wall, make the people wonder!!??
what u should of done is make a template to fit perfect and then copy cut that to the timber with a router that way u know it will fit excactly. Personally i like the rogh look as a tree is never perfect and therefore should be left natural looking as possibe, just a thought!!
Did you ever find someone to do the boat timber work? I can't find the contact details on the guys down at the Gut - although any of the marinas down there should know them.
Wheres the work bench???????????
I like the rough edge. I've changed my mind. Is it too late Craigie?
The best use of a kombi IMO. Cool idea!
Perhaps you could use some hippy curtins on the wall that's visable through the cab?
How about turning the front of the hillclimb car your rear-ended at Baturst into a matching BBQ or love seat?
CYA CT
At the rate water gets into the car when I'm driving on really wet roads it could probably sustain some fish!
I think the seal (fur seal) moved slightly when I fitted the body to the pan. I might have another go at it in a few months.
Beetles should float shouldn't they?
CT
