need this real quick, wheel nut on buggy is off a Porche is that likely to be a standard VW size?
ta
don
You mean wheel nut??
Whatever - VW and Porsche are both metric.
So...it is standard VW in that they are both metric
Thanks for that Biz, made a few phone calls to specialist wheel suppliers but they couldn't help, took a drive to visit their shop but still no good "take it to an engineering place and get em to measure the thread"was the best they could do, on the way home saw a Bob Jane store, whiped in and the bloke identified it straight off, wiped out a set of threads on a ring to confirm, showed me a couple of choices then says their the same as on the Crewman I am driving, he was able to supply them complete with the plastic caps. another win for Bob.
yep, thats what I needed, the bloke who i bought the car off had ball taper nuts on straight tapered rim, had the car for two years before I needed to remove a wheel thats when I found it, didn't help that I lost a couple of the porshe nuts and needed to replace them.
Porsche is 14x1.5mm same as Kombi
