Quik motor stand Q??
robnjo - April 1st, 2008 at 08:53 PM
can a bug motor bolt-up to a motor/Engine Stand...maybe 1 from Supercheap?
1303Steve - April 1st, 2008 at 09:02 PM
They can, but I think the flywheel gets in the way unless you use some stout spacer tubes.
Pumba - April 2nd, 2008 at 05:40 AM
Get a belhousing from a kombi gearbox and bolt that to the engine stand then bolt your motor up this way you can start the motor on the engine stand also cheers shane.
