Skip to content
Aussieveedubbers
aftermarket carbies
Share Share on Facebook Share on X Share on Reddit
Log in to reply
baja burley Officially Full-On Dubber
325 posts · joined Sep 2008 ·
#670544
what sort of aftermarket carbies would i be looking at for my stocko 1600? twins? what sort of hp change will i get?... what will it do to my fuel consumption?... all that jargon... any info or help would be appreciated
There are three types of people in this world - people who can count and people who can't....
greedy53 Bishop of Volkswagenism
3,062 posts · joined Mar 2006 ·
#670556
for a 1600 tp i would go for a set of cadrons with an exhaust upgrade to extractors not sure of hp gain but it go go better and as for fuel usage should not be excessive it will depend on your driving flatout a lot of fuel safe good fuel
good luck
LIFE IN THE LOW LANE All people have the right to stupidity but some abuse the pr
2,534 posts · joined Mar 2007 ·
#670561
40mm dellorto's or webers. fit smaller venturi's and adjust jetting to suit your engine. Add a quality exhaust system for more efficiency.
ACCEPT THAT SOME DAYS YOU ARE THE PIDGEON AND SOME DAYS YOU ARE THE STATUE
VWCOOL 23 Windows of Awesome
5,158 posts · joined Jun 2003 ·
#670578
Kadrons. A second-hand set is cheap and cheerful and with a 009 distributor and a set of cheapie extractors, will make it more lively
Pay your debts, CxxT
#670586
know where i can get all off this stuff without goin to the big boys and gettin ripped off???
#670624
Maybe try a 'Wanted To Buy'...
#670718
i am thinking of a centre mount, single or double barrell 36-40mm progressive carb... i am plannig to do some mild offraoding... hows this for an option?? am i on the right track?? and how much would i be looking at for a carbie of this calibur??? and does anyone have a ballpark figure on horsepower gain for this carbie??
#670894
what brand should i go for??
Bizarre Moderator The artist formerly known as blue74l
12,796 posts · joined Aug 2002 ·
#670908
baja burley wrote:and how much would i be looking at for a carbie of this calibur???
are you going to set up and jet this yourself or are you wanting a drive in drive out
Craig Torrens 6 times Australian, 7 times State Hillclimb Class Champion
8,040 posts · joined Jan 2003 ·
#670909
with a stock motor you may get 3 or 4 more hp......if your lucky !
barls Administrator Causer of Chaos and Mayhem
9,478 posts · joined Jun 2004 ·
#670959
baja burley wrote:i am thinking of a centre mount, single or double barrell 36-40mm progressive carb... i am plannig to do some mild offraoding... hows this for an option?? am i on the right track?? and how much would i be looking at for a carbie of this calibur??? and does anyone have a ballpark figure on horsepower gain for this carbie??
i sold my last complete one for 350, that was ready to fit
the chaos project - click me
#670999
a bolt up and drive away one would be nice but i can set it up if i have too....
really!?! - only 3-4 hp?? i thoght it would be more than that.
#671054
5-10% gain in power..............remember a 1600 isn't pumping out big HP !! With the Kadrons you will feel a lot more torque, so it will feel like it has added a lot more HP... Just make sure you upgrade the exhaust as well.
#671098
so kadrons is the go if im gonna do some offroading??
#671099
i have been looking at exausts to upgrade and have found a few decent ones but what is the difference between headers and extractors and which is better??
Stanley I guess the reward is in the doing of it
4,523 posts · joined Mar 2003 ·
#671102
Thunderbird extractors a pretty good and you can chose the style of muffler. Is it a baja?
pete wood 23 Windows of Awesome
6,828 posts · joined Jan 2004 ·
#671105
VWCOOL wrote:Kadrons. A second-hand set is cheap and cheerful and with a 009 distributor and a set of cheapie extractors, will make it more lively
even second hand, kadrons are not cheap anymore. 🥲
#671109
yeh its a baja super in the making... see how it goes....
so extractors and headers are the same thing??
some fella has a pair of 32/36 webers for 100 bux, no manifolds are they worth it??
#671111
progressive linkage 32/36 weber would work well. All you need to get is the right manifold.
#671115
I had a thought, I could be dreaming, but what about a drawthrough turbo setup. Probably cost about the same cash as a kadrons, manifolds and linkage and would make for a bigger torque/power increase. You'd have to be careful about overboosting it, but premium unleaded would help.
What do you think stanley?
#671116
Thought centre mounts were the go for baja's and buggies??
#671117
pete wood wrote:I had a thought, I could be dreaming, but what about a drawthrough turbo setup. Probably cost about the same cash as a kadrons, manifolds and linkage and would make for a bigger torque/power increase. You'd have to be careful about overboosting it, but premium unleaded would help.
great idea...there is precedence somewhere for that...🤪
Also just realised i replied to the wrong post. Thats what happens when you're trying to hide your internet use at work.
#671118
i havn't even got my licence yet so a turbo is off the cards (stupid P plate laws)...
does anyone know the specific manifolds i need and pricing?
and are the webers worth it???
#671121
im in QLD
matberry Moderator Go hard or go home
8,114 posts · joined Mar 2006 ·
#671124
The progressives will work but only as a single, unless you do some interesting engineering.🤪
#671126
there use to be a manifold set for a twin set up with the progresives but it hasnt been made for about 10 years, ive only seen 1 set and thats on twoguns split. here is the manifold that you need for the single mount
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D5500
and here is the whole set up
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D47%2D0622
#671132
will the stock manifold work if its just a centremount??
#671143
Yes, you use the stock end manifolds and the centre mount manifold then goes straight into them. BTW, a word of warning, the EMPI brand has had negative things said about the quality of the it's weber reproductions. If you can, I think you might find a rebuilt italian or spanish 2nd handie might be better than a brand new chinese EMPI. I may be wrong on this, but everything I'm hearing from experienced carb users in the states says EMPI stuff is not great. This is added to the colourful reputation the progressive has on VWs. I've personally heard great things about the use of weber progressives on subarus, old peugeots and escorts, so I can't see why VWs engines would be any different, but there you go.
Your other alternative is to try and find a set of cheap 36idfs like I did. They were on Alfa 33s. These are great little carbs and would be well suited for an offroad 1600.
