fasty popout rubbers
butidontunderstand - September 30th, 2008 at 07:08 PM
is there anywhere I can get some fasty popout rubbers?
I was told they aren't being made anymore!
cheers, karina
vw54 - September 30th, 2008 at 07:52 PM
yep keep yr old ones cause NO one has got them
mackaymanx - September 30th, 2008 at 07:54 PM
http://www.vwispwest.com/home.php ISPWEST have done a reproduction.
http://www.thesamba.com/vw/classifieds/detail.php?id=589262
http://www.thesamba.com/vw/forum/viewtopic.php?t=180355&postdays=0&po...
1500S - September 30th, 2008 at 08:00 PM
Yep Dave. Been out for a while now. Here is where we put it on AVD some time back.
http://forums.aussieveedubbers.com/viewtopic.php?tid=68880#pid643592
DH
vw54 - September 30th, 2008 at 08:07 PM
GO 4 it if there still available
has anyone actually bought these
Bizarre - September 30th, 2008 at 08:20 PM
Get in touch with Andrew with the subie Fastie
Believe he made some fron Clarke Rubber stuff
butidontunderstand - September 30th, 2008 at 08:40 PM
o0o0o0o0o0o0o0o I will send him a u2u
Notch Nut - September 30th, 2008 at 10:22 PM
If you are in Melbourne,
Centre Rd Car wreckers (self serve) had a fasty a while ago with pop outs. Some klutz smashed a window in an attempt to remove it but the rubbers
were still there last time I checked.
butidontunderstand - September 30th, 2008 at 10:26 PM
no not in melbourne unfortunately, spend most of my time in brisbane but am in coffs this week at the parents house
Notch Nut - September 30th, 2008 at 10:33 PM
I managed to salvadge the hinges for my retirement fund but couldn't remove the glass without breaking it.
Apparantly the guy after me couldn't do the same either!
amazeer - October 2nd, 2008 at 01:08 AM
what hinges?
butidontunderstand - October 2nd, 2008 at 07:12 AM
popout hinge type things I think?
1500S - October 2nd, 2008 at 08:27 AM
Quote: |
Originally
posted by Notch Nut
Forgot to undo the 4 screws which holds the bendy glass rubber into the body did we??
Go for the new stuff from ISP. Has to be better than trying to make it from some non genuine section. Cut the inside lip from the old rubber to
lessen the chance of any breakage. It'll work out cheaper in the long run as well as look right.
DH
Notch Nut - October 2nd, 2008 at 10:12 PM
Quote: |
Originally
posted by 1500S
Quote: | Originally
posted by Notch Nut
DH
Nope. I realised that the glass ain't coming out unless the rubber got cut (never knew about the extra screws until now), so I just took the hinges
for myself (unbolted of course)
. I went back the following week
and one window was busted completely so I am assuming that someone tried to salvage that which I could not.
Stupid thing is that I don't even own a Fasty???
- Adam
