engine ID
baja burley - October 3rd, 2008 at 08:24 PM
hi guys i bought a 1600s/p today and the number on the case is
F 1586450
can you help with ID of the engine
i had a look at the pistons and they read
85.05
any tips appreciated!!!
baja burley - October 3rd, 2008 at 10:31 PM
is the crank and internals all the same between 1300's and 1600's??
whatnow - October 4th, 2008 at 06:33 PM
at some stage they added oil troughs to the cranks' rod journals (i think they also increased the crank oil passage sizes but don't quote me on that). i know they didn't have the troughs on 66/7 1300's and did have them on the dp1600's i pulled apart. when this change was made i don't know off hand.
the cases changed over time, going to dual pressure relief valves, larger oil passages, slightly different positioning of the oil pump feed hole and some casting/webbing differences. there were different sized oil pumps, dished/non dished cams, 6V 180mm 6V 200mm and 12V 200mm flywheels, differences in the rods plus prob dozens of other things i don't know/can't remember.
baja burley - October 5th, 2008 at 07:59 PM
thanks whatnow!! that clears up a few things... does anyone know any links that go into detail about these two engines??
