Hi all,
Have a problem with my OS (XP Pro), every time I open a new link in Explorer, the new page opens but does not link to the new site/link.
I have gone into Explorer/tools/internet options/advanced. I have had a play around there for a solution....but no good!
Does any one out there have any ideas......other then going for "red hat" or another OS!
Hope to get a solution soon before I turn the whole system into wheel chock for my Kombi!
Mick H
Can you explain "New Link" do you get your home page ?
I had that once ... i could only ever open one window with IE
I fixed it by running all the updates then it went away .......
Other suggestion is to ring your isp
that's an easy problem to fix
change to Apple
kombilova
Besides the simple things, like have you set a slow loading home page (I use about :blank), you might want to check a few things:
Have you installed any IE "helper" apps, like the Google toolbar, Acrobat, etc? These toolbars and helpers are notorious for causing IE to
hang.
I would suggest going to http://windowsupdate.microsoft.com and see if
there's any patches for your browser. Apply any and all of them. May help.
If not, go to http://www.microsoft.com/ie/ and download the latest IE 6.0 SP1
setup.
Andrew
